Buy Now
eFPGA IP 2.0 – Development Flow
Schedule a Demo
Define
Step 1: Understanding Your eFPGA IP Requirements
  • Supports partitioning across heterogenous eFPGA e.g. LUTs, DSP blocks, and Block RAM
  • Leverage our Continuous Benchmarking System to use our standard benchmark designs or use your own to determine the eFPGA architecture and size that will work for you.
Step 1 flow diagram Aurora logo
Define
Step 2: Defining the Right eFPGA IP for You
  • With the results from the Evaluation phase, QuickLogic’s Australis tool will help optimize your eFPGA Logic Array to meet performance and area requirements
  • Define the type of Logic, RAMs, DSPs and how they will combine into your custom eFPGA IP
  • Define your eFPGA array size and aspect ratio that suits your SoC/ASIC floorplan
  • Create your eFPGA to ASIC port mapping for integration
Step 2 block diagram Australis logo
Define
Step 3: Australis Generates Your IP Files
Step 3 process icon Australis logo
Define
Step 4: Integrate Your eFPGA Into Your SoC
  • Meet your design goals – for performance, cost and time-to-market.
  • QuickLogic’s highly experienced FPGA design team will reduce your project risk by supporting you in the integration of the eFPGA IP into your own chip development flow, including test vector generation.
Step 4 Support Icon Australis logo
Define
Step 5: Freedom to Innovate
  • Our support doesn’t end after you go to production with your new eFPGA-enabled semiconductor device.
  • Target your custom eFPGA with SymbiFlow 100% Open Source OR optional support for advanced features within QuickLogic’s Aurora FPGA User Tools
  • Faster Run Time & Integrated Timing Analysis Tools
  • The tools are continually advancing so that you can focus on innovating and drive value for your customers
Step 5 Flow diagram Australis logo
button - scroll to top
