Ignite Your IoT and AI Projects with SparkFun Thing Plus
Versatile, Low-Power Development Platform for Smart Devices
Buy from SparkFun Buy from Crowd Supply
The Ultimate Platform for Your Smart Device Project
The SparkFun Thing Plus – QuickLogic EOS S3 Dev Kit is the ultimate platform for developing IoT and AI applications. With its powerful combination of Arm® Cortex®-M4F MCU and embedded FPGA, this kit provides unmatched flexibility and low power consumption, making it perfect for a wide range of smart device projects. Whether you’re building next-generation wearables or edge AI solutions, the SparkFun Thing Plus offers the tools you need to bring your ideas to life.
QuickLogic EOS S3 SoC
Combines Arm® Cortex®-M4F with eFPGA for robust performance and flexibility.
Low-Power Consumption
Optimized for ultra-low power operation, ideal for battery-powered devices.
Embedded FPGA (eFPGA)
Provides 2,400 logic cells for customizable hardware acceleration.
16MB QSPI Flash Memory
Ample storage for your applications and data.
Flexible Interface Support
Includes SPI, I2C, UART, and GPIO for versatile connectivity options.
Onboard Sensors
Integrated 6-axis IMU and PDM microphone for motion and audio applications
Compact Form Factor
Compact Form Factor Small, breadboard-compatible design for easy prototyping.
Open-Source Compatibility
Fully supported by open-source development tools, including Zephyr RTOS and FreeRTOS.
Flexible and Scalable Development
eFPGA and multiple interfaces offer customization and scalability for a variety of applications.
Energy Efficiency
Low power consumption extends battery life in portable devices.
Rapid Prototyping and Seamless Integration
Compact, breadboard-friendly design and open-source tool compatibility ensure fast development and easy integration with existing workflows.
Versatility in Application
QuickLogic EOS S3’s adaptability suits projects of varying complexity and scale, from simple IoT devices to advanced AI applications.
Qwiic Connect System
Thing Plus features SparkFun's Qwiic connect system, which makes prototyping and development a snap:
  • Tons of expansion boards: There are hundreds of Qwiic-compatible expansion boards to choose from, including everything from RFID readers to displays to keypads
  • No soldering: Qwiic cables (4-pin JST) plug easily from development boards to sensors, shields, accessory boards and more, making it easy to set up a new prototype
  • Polarized connector: There's no need to worry about accidentally swapping the SDA and SCL wires on your breadboard - the Qwiic connector is polarized so you know you'll have it wired correctly every time, right from the start
  • Daisy chainable: It's time to leverage the power of the I2C bus! Most Qwiic boards will have two or more connectors on them, allowing multiple devices to be connected
Applications
Edge IoT Applications
Develop smartwatches, fitness trackers, and other wearable tech with advanced motion and audio sensing.
IoT Designs Using MCUs and FPGAs
Create low-power IoT solutions that perform real-time data processing at the edge.
Ultra-Low Power IoT Applications
Implement AI/ML algorithms in edge devices for smart, autonomous operation.
Portable and Battery-Powered Gadgets
Design energy-efficient portable electronics with extended battery life.
